Discovery Start Problem
Old Nov 15, 2008 | 05:27 PM
stuartn00's Avatar
Default Discovery Start Problem
We have a 1995 LR Discovery manual transmission. For some months now, after it has been starting fine, we will get in, the ceiling light & ignition light will go on with the open door, but when we put the key in the ignition these lights go off & all power cuts off. When we turn the key, nothing happens. After a few days, we come out & do the same, and the car starts right up with no issue, but not if we try soon after this happens. Yesterday, this happened. I inserted & removed the key a couple of times, depressed and released the clutch, jiggled & moved the gear shift in and out of neutral. Nothing happened. Finally, I tried slamming the driver door very hard. Presto-the power came back & I started the car right up. I am guessing some kind of loose wire somewhere, but don't know where.
Any thoughts/suggestions would be very much appreciated. Thanks in advance. Stu
Old Nov 15, 2008 | 09:10 PM
Default RE: Discovery Start Problem
Check your battery cables first, then check for loose grounds.
http://www.roverparts.com/TechTips/g...l_problems.cfm
dmatranga
Feb 5, 2013 12:27 AM
armyeng
Mar 8, 2011 05:58 PM
fishhawk
May 19, 2010 07:55 PM
nfakbc
Apr 8, 2010 03:51 PM
Jorge
Feb 11, 2005 09:15 PM
