DIY oil/trans cooler lines and connectors?
Old Jan 27, 2017 | 11:27 PM
Jeff Blake's Avatar
Default DIY oil/trans cooler lines and connectors?
Spent an hour or so today trying to work a transmission line back onto the cooler. No luck... So much for "quick" connect.
Anyway after staring at the line for awhile, I noticed the flexible portion is pretty well cracked and worn. OCD kicks in, so I look for a replacement line. Turns out they aren't manufactured anymore, and its a bear of a job to disconnect the end at the transmission anyway.
So I see an opportunity to put in something better than OEM
Two ideas
1. Cut out the rubber hose, put a new one in with stainless steel high pressure hose clamps. Easy. Would it hold?
2. Replace the rubber hose with a braided SS line, threaded at each end. Use compression fittings for each end to fix to the cooler and hard line.
Has anyone done a DIY on these flexible lines and can share some tips?
Old Jan 27, 2017 | 11:48 PM
Luckyjayb's Avatar
I think robert booth was having some issues like this and actually took the lines to a local hydraulic shop and had them make some
Old Jan 28, 2017 | 10:32 PM
Twix's Avatar
I've done aftermarket coolers in Mustangs and T-birds, never did I use SS braided lines. Just high pressure rubber hose, never failed either. Transmission lines shouldn't have much pressure in them. Make sure the cooler has flares and don't over-tighten the clamps, get a decent cooler as well.
blurover
Nov 29, 2013 01:26 PM
javven
Jul 15, 2012 10:09 AM
Spike555
Jun 1, 2012 09:23 PM
cdm
May 29, 2012 01:52 AM
