DIY tips for Rain X Latitude blades w/ DII arms.
Old Feb 21, 2014 | 08:26 PM
  #71
Dan7's Avatar
subscribed
Old Mar 12, 2014 | 01:41 PM
  #72
wyrdvans's Avatar
Just bought some rainx latitude 20" blades and it looks like they changed the design pretty much. I don't see any way to make it work without heavy modification to the wiper blade mount.
Old Mar 12, 2014 | 02:02 PM
  #73
Dan7's Avatar
I found a 50% solution by bending the "C-Clip" at the base of the wiper arm closed more, and bending the metal the wiper blade is attached to at the ends to create better contact with the windshield. Still flutters a tad at highway speeds, so I know there's not a lot of downforce, but the smears of on the untouched portions of the windshield definitly shrank.
Option for cheaper replacement are the universal cut-to-fit refills which work fine and are <$4 each.
Old Mar 13, 2014 | 07:32 PM
  #74
jalodge's Avatar
I took the plastic cover off of the metal and drilled a hole through the mount. Then I put a small bolt with a nut through it to hold it in.
Old Mar 15, 2014 | 04:30 PM
  #75
SDinDS's Avatar
I'm using the Michelin Stealth wiper blades. I removed everything from the arm, widened the tabs towards the lower part of the arm (where it held the factory blade in place). The new blade is held in with a plastic push pin (universal body panel type).
Old Jun 28, 2016 | 11:22 PM
  #76
wozapinin's Avatar
The pictures won't show for me, bought a set and maybe I haven't been supplied with correct clip?
Drillbit
Apr 4, 2014 02:10 PM
slickzero76
Feb 21, 2014 05:44 PM
Torancis_LR
Dec 18, 2011 10:37 PM
Chris-bob
Off Topic
Sep 8, 2011 01:44 PM
millejdq
Dec 6, 2007 12:23 PM
