Do you really need to remove cat pipe and muffler to drop transfer case?
Old Nov 17, 2022 | 06:12 AM
austinlandroverbill's Avatar
RAV says nothing about removing the transmission output shaft itself.
I thought that transmission output shaft was fixed and that the transfer case slid off of it with the assistance of the guide studs.
Old Nov 17, 2022 | 06:35 AM
XRAD's Avatar
you do not have to remove transmission output shaft to change out the T case...
you should replace all the seals while you have easy access....
Old Nov 17, 2022 | 04:29 PM
SundayFunday's Avatar
I didn’t say you have to.
youll see
Old Nov 17, 2022 | 05:14 PM
Harvlr's Avatar
For the O2 sensor connectors, I don’t know if you can get away with this on the D2, but I recently needed to remove the Y-pipe on my wife’s Mustang. The forward connectors were very difficult to access so I just removed the sensors from the pipe instead, with the wiring still connected.
Old Nov 18, 2022 | 07:40 AM
I've done that before -- remove the O2 sensor at the pipe and leave it connected to the harness --- when I've had to do a pressure test (checking to see if the cat converter was clogged -- turned out my relocated coil packs were the issue) in the bunge itself. Only challenge is when putting them back in, you have to "pre-twist" them.
I have to click the CPS connector back into its mount so looks like I'll be fiddling up along the firewall anyway.
Old Nov 18, 2022 | 05:25 PM
Harvlr's Avatar
I counted the turns out an then pre twisted the harness the same amount on install.
Old Nov 19, 2022 | 07:24 AM
Thanks. One of those little attentions to detail. Sometimes the obvious isn't.
My little addition to this is to put a mark on the O2 sensor to get the count right.
I use nail polish to mark things: more durable marking than a paint pen, buy it for a buck (now $1.25) at DollarTree.
mutant
Apr 11, 2017 05:16 PM
SWAINROVER
Dec 5, 2015 04:38 PM
cornbreadj
Apr 5, 2015 09:20 PM
94svt50
Dec 30, 2014 03:09 PM
ajh
Oct 23, 2006 09:42 PM
