Does a '01 4L engine bolt to a '04 4.6L transmission
Old Mar 12, 2017 | 06:08 PM
twin6's Avatar
Default Does a '01 4L engine bolt to a '04 4.6L transmission
I understand there are a few differences between a '01 4L and a '04 4.6L engine (like the cylinder liner capture method and longer stroked crank). I also know there are differences in the '01 and '04 transmissions.
I just want to validate that my '01 4L engine will bolt right into my '04 Truck and transmission with no problems.
Any insight from those that know 100% for sure will help me immensely.
Old Mar 12, 2017 | 06:22 PM
abran's Avatar
100% sure, plug and play
Old Mar 12, 2017 | 07:18 PM
twin6's Avatar
Thank you. As many hours as it has taken to remove the 4L and looking to many more for getting the 4.6L out, it is excellent to know that there will be no fit surprises on install day (whenever that will be....)
Old Mar 12, 2017 | 07:36 PM
mln01's Avatar
Abran, I don't doubt you at all but isn't the ZF4HP24 trans in the '03-'04s slightly longer than the '99-'02 version? If so how is that 20mm extra length accommodated in the setup?
Old Mar 12, 2017 | 09:51 PM
Fast951's Avatar
Hopefully your 2001 4.0L engine is Bosch going to the 2004 vehicle which is also Bosch. If your 4.0L is from a GEMS vehicle the crank position sensor mount at the LH rear of the engine will be different and will need to be retrofit to use the Bosch CPS.
Old Mar 12, 2017 | 11:54 PM
Southern's Avatar
I recently took a 4.0 GEMS from a '96 D1 with a manual transmission and installed it in an '03 D2.
I had to modify it to work with the '03 BOSCH system (CPS mount changed, front cover changed, timing gear swapped, etc...) but it bolted right up to the '03 automatic transmission.
So I had an '03 D2 with a 4.0 engine. Even left the D1 heads on it. Had SAI errors, but that was all.
Old Mar 13, 2017 | 12:12 AM
abran's Avatar
The difference is from bell housing back. The trans and t case mounts are different and the difference in length taken by the driveshafts.
DR.DREW2
Dec 21, 2016 01:02 PM
DR.DREW2
Dec 5, 2016 09:39 PM
Disco2Mike
May 4, 2015 08:22 PM
focusontheworld
Oct 21, 2012 01:00 AM
