Does a 4 inch lift with 31's or 32's look silly?
Never heard the term "dropping kit" before. Because, basically, they go beneath the coil spring and are lifting the body more. No way to "drop" the axle...unless you dug a hole under them...or used smaller tires.
Anyhow...
Your rover looks great though, how many other things did you do...once you went 4" of lift? Just removed my 2" spacers, when installing a 2" coil spring lift. Thought about leaving the spacers to achieve 4", but this is my daily and having it down for a while didn't interest me at the moment. However, someday...l'd like to maybe go 4" inches and much larger tires. Did you get longer shocks or modify the shock towers/mounts?
Brian.
Anyhow...
Brian.
There's quite a few things you need to. Here is a link to the kit D2 White Tiger 4" Lift Kit (Installation Kit Only). Unfortunately though, he's no longer making them. Instead he's doing a 2" body lift kit. Have a look at his Storm D2 with LS engines in them.
John Frederick
Nov 26, 2016 06:33 PM
