Does anyone know what this part is????
Old Nov 26, 2008 | 06:40 AM
2000 DII's Avatar
Default Does anyone know what this part is????
It is 2" in diamter and made of rubber. I found itunder my truck.
Old Nov 26, 2008 | 07:50 AM
jmrivera's Avatar
Default RE: Does anyone know what this part is????
Where under the truck did you find it - on the ground? Can you be a little more specific?
Old Nov 26, 2008 | 08:37 AM
humroot's Avatar
That is a seal for the transmission. Slide under your truck and look at your transmission. Towards the front of the tranny, towards the top you will see a big hole where that goes. Just push it back in.
Old Nov 26, 2008 | 08:44 AM
Clean it off good first, check for tears in the rubber, if torn, buy a new one so it won't come off and get lost.
Old Dec 2, 2008 | 12:40 PM
2000 DII's Avatar
O.k., sorry for the long delay in my reply. I finally finished that dang turkey and ham. Ha ha
Iskinnied under the truck and I swear I can't find where that seal belongs. There's a lot going on down there and not much room to reach anything.
Can you clue me in a little more where it's supposed to go? I guess first of all I need to go buy a new one.The rubber is torn as Mike had guessed. This is nota rover dealership-only part is it?
Old Dec 2, 2008 | 01:23 PM
98roverguy's Avatar
http://www.roverparts.com/ProductLis...amp;PartNumber=
I don't see it as a tranny seal.
Old Dec 2, 2008 | 02:47 PM
mcneal's Avatar
It is on the rear of the oil pan. one on each side, where the pan meets the flywheel cover. the oil pan kinda has two flanges on each side that bolt up next to the flywheel the holes are on that flange. you can remove the rubber seals and see the teeth on the flywheel. if i had the rave cd here at work i would attach a picture, sorry.
looking at the usual part sites, im getting the feeling its a dealer part.
*edit* attached picture. holes on vertical "flange"
Old Dec 4, 2008 | 05:40 AM
2000 DII's Avatar
Awesome. Thanks for the picture!
tornado_735
Mar 31, 2009 09:33 PM
2000 DII
Nov 26, 2008 10:30 AM
riggskwong41
Oct 14, 2008 12:24 AM
cst756
Apr 8, 2008 09:48 AM
andrewcloy
Nov 27, 2007 09:15 AM
