Does Your A/C Condenser Electric Fan/Motor Work?
Old Jun 4, 2017 | 11:14 AM
  #21
toofaroffroad's Avatar
Is there a way to test if the fan is working aside from overheating engine? Anyone know of a way to trigger it? Thanks
Old Jun 4, 2017 | 12:17 PM
  #22
Best4x4's Avatar
Turn on your A/C and once the pressure builds up it should come on. Or remove your grill and attach 12v battery to it.
Old Jun 4, 2017 | 12:33 PM
  #23
LR03NJ's Avatar
Get a barbcue stick and try to reach and spin the blade without removing the grill. If its stuck, its dead.
Old Jun 5, 2017 | 11:30 AM
  #24
My AC doesn't work. It hasn't since I bought the thing last year. The condenser fan turns but it's not smooth.I have never been anywhere close to overheating. I sit at 188-195 all day long even towing my 3500lbs tent trailer up steep hills.
I'm wondering if this is even something I need to fix.
I most likely will just because.
I would not have even known about it but I noticed that 40amp fuse blown under the hood when tracking down a separate issue.
Old Dec 4, 2017 | 05:46 PM
  #25
coop74's Avatar
if you have an aftermarket bumper you can do it from the bottom as well. I actually got an old connector and made a pig tail to plug into the fan (the car side) and hooked it to a battery... no turn
No to put in the harvested one.
there is a You tube video about replacing the brushes which is what seems to fail the most if you believe the presenter.
EstorilM
Oct 8, 2019 08:26 AM
jafir
Feb 10, 2017 11:08 AM
Cromwell
Oct 23, 2015 08:10 PM
jmt
Jan 14, 2008 05:01 PM
