Doing Head Gasket, what else while i'm at it?
So my '01 DII with 103k needs some head gaskets. I've been going through the same 'ol, same 'ol "magical coolant loss" and "suddenly no heat" and one short overheat (like a minute). I replaced the tstat and water pump, which was pretty wobbly and leaking a bit.
Now that the water pump is tight, the system is really starting to pressureize. After multiple cycles of bleeding the RAVE way, I'm still getting air in the system. Heat comes and goes. That being the case, it's pretty clear I'm in need of HGs.
I found a local non-dealer rover shop, and they quoted me 1250 for the job. I'm also providing them with some new STI plug wires to install when everything comes back together. Seems like a decent deal to me. Thoughts?
While I'm at it, what else should I do/address, assuming most things look good once it's apart? Hoses?
Thanks!
Thanks!
I got my Disco back on Tuesday, and I couldn't be happier! Runs smoother, more power, quieter, picked up about 3MPG, blah blah, blah. 1,400 for the whole deal.
New water pump, STI plug wires, and t-stat on top of the HG job really made a huge difference. Now I just need some shocks...
103k, and hopefully another 100k ahead
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
MattyJ2000DiscoII
12-19-2012 09:32 PM
grandkodiak
05-16-2011 01:57 AM
XxRoverAllOverxX
10-04-2010 02:47 PM
Robwsup
03-11-2010 10:28 PM
