Door key does not work.
Old Dec 24, 2024 | 01:54 PM
evil_goat's Avatar
Question Door key does not work.
On the drivers door, the key goes in fine, but when I turn it, it spins left and right loosely and does nothing. I have a feeling something is disconnected or snapped, but I am not sure what. What could be the issue here? The door locking button on the inside operates the locks fine, and the key fob has been lost long ago, so I have no options for locking the car.
Old Dec 24, 2024 | 02:04 PM
PickleRick's Avatar
There's a door lock pin. I believe the original is made out of weak cheap pot metal. Purchase a new one made out of steel.
I can't remember if the door handle has to come off or the door panel. Either way it was an easy install. I did so preemptively years ago.
For keyless door locks an 80 dollar Chinese blue tooth obd two ways dondle and a 30 dollar Amazon key got us keyless entry again.
Or rent a nanocom
Old Dec 24, 2024 | 02:22 PM
mollusc's Avatar
carrs4x4.com sell the upgraded door lock pin. You need to remove the door handle, and to do that you need to remove the inner door card.
It's a pretty well-documented issue on this forum. Doing a search should bring up some photos to help.
Old Dec 24, 2024 | 04:40 PM
whowa004's Avatar
Or rent a nanocom
info on the keyless lock?
Old Dec 24, 2024 | 04:54 PM
PickleRick's Avatar
https://landroverforums.com/forum/di...13/#post881324
Old Dec 25, 2024 | 03:26 PM
evil_goat's Avatar
I took the door handle off and saw that it indeed was broken. I found one from atlantic british https://www.roverparts.com/body-chas.../LRD2-DOORPIN/
Old Dec 26, 2024 | 09:49 AM
mollusc's Avatar
That's the Carrs4x4 pin, being sold by AB.
jamanta
Sep 4, 2015 02:33 PM
Drubie22
Sep 24, 2014 09:29 PM
Disco Dancer
Oct 29, 2013 09:48 PM
ncdisco
Jul 6, 2012 07:56 PM
Disco2Guy
Sep 21, 2007 09:20 PM
