door lock
Old Sep 20, 2007 | 12:17 AM
suveer's Avatar
Default door lock
Hi guys
i have come across numerous posts where the guys complain about the door not being able to open without pulling upthe lock and opening the door simultaneously. The common fault was said to be a spring that needs changing because it loses its tension.CAn some please advise where this spring is situated and how to get to it.
Your help will be appreciated.
Many thanks
Suveer
Old Sep 20, 2007 | 06:54 AM
Default RE: door lock
I have never heard of replacing a spring. If your door does not unlock, you have a bad lock actuator that needs to be replaced.
Old Sep 20, 2007 | 06:56 AM
suveer's Avatar
Hi Mike,
Thanks, The door unlocks but it stops short of 1mm from fully unlocking.Is this still the actuator.
Thanks
Suveer
Old Sep 20, 2007 | 07:01 AM
Darover's Avatar
You can check ebay for the spring you're looking for. I think that its made for D1 and the ad usually says to contactthem for D2 applications.
Old Sep 21, 2007 | 04:37 AM
suveer's Avatar
Thnaks guys, but where is this soring located and how do i get to it. Does someone have a diagramm please
Old Sep 21, 2007 | 11:04 AM
ajh's Avatar
ajh
Hrm, I know I did a supplemental spring for the rear door latch which helped a great deal (combined with cleaning and lubing the handle itself), haven't looked at the fronts yet but will next week when I get home since it looks like I had an acuator fail this week.
kpl1228
Aug 19, 2012 05:33 PM
CandiMan
Aug 24, 2008 10:35 PM
