Door lock actuator fixed - now reversed
So I did the lock motor fix for my passenger side rear door actuator. Kind of a PIA project but got it done. It works now but is reversed. Unlocked when locked etc. Is this because the motor is spinning in the wrong direction? If the case, does anyone know what motor works on the passenger side? Most on ebay do not indicate direction of shaft travel. Thanks!
Uggghh, never mind. Found the answer, need the CCW motor.
No. I used the "dremel the case apart" method. Works but is ugly. There are several threads on this I will link to tomoorow.
bcolins
Nov 8, 2011 06:15 PM
