Door lock actuator fixed - now reversed
Old Jun 26, 2022 | 10:17 AM
dswilly's Avatar
Default Door lock actuator fixed - now reversed
So I did the lock motor fix for my passenger side rear door actuator. Kind of a PIA project but got it done. It works now but is reversed. Unlocked when locked etc. Is this because the motor is spinning in the wrong direction? If the case, does anyone know what motor works on the passenger side? Most on ebay do not indicate direction of shaft travel. Thanks!
Uggghh, never mind. Found the answer, need the CCW motor.
Old Jun 26, 2022 | 12:49 PM
Sandman614's Avatar
Replied to your PM. I have 9x CW rotation motors left for the Normal Lock, the Super Lock needs a CCW rotation motor. This is determined as viewing down the shaft towards the motor.
Old Jun 26, 2022 | 03:36 PM
longtallsally's Avatar
Got any pics of the tear down of the actuator? I tried it and chickened out…
Old Jun 26, 2022 | 10:02 PM
dswilly's Avatar
Thanks for the reply. So the passenger side non super lock motor is CW?
Old Jun 26, 2022 | 10:05 PM
dswilly's Avatar
No. I used the "dremel the case apart" method. Works but is ugly. There are several threads on this I will link to tomoorow.
Landrolet
Jul 13, 2023 09:02 PM
Brad S1
Jan 23, 2018 09:02 AM
llPANCHOll
Aug 21, 2009 09:18 PM
starcraft
May 11, 2009 08:05 AM
