Replacing the door lock actuator
Old May 10, 2009 | 09:31 PM
starcraft's Avatar
Default Replacing the door lock actuator
Hello all,
The passenger side door lock on my D2 stopped working and I was looking to replace the motor inside of the lock actuator. However, I have been reading posts on here saying that you cant get into the D2's lock actuator (you can only do so on a D1). Is this true? If not, is there a special technique I have to use to get in there. I'd hate to go through the trouble of getting the thing out of the truck just to find that I cant replace the motor. Any suggestions will be appreciated. Thanks
Old May 10, 2009 | 10:11 PM
sforb's Avatar
you can replace it, I had to take the window frame most of the way up and out.It is a challenge to get the linkage hooked back up! you need small hands!
Old May 11, 2009 | 07:46 AM
starcraft's Avatar
Thanks for the reply. I think i can get the unit out of the truck. I just need to go to the store and get a bigger size bit for the door screws. As for removing the little motor inside of the actuator on a d2, is there anything special i need to know. Is this even possible. Im nervous because a couple of the old posts say that it is impossible to open the unit. Please get back to me. Thanks
Old May 11, 2009 | 08:05 AM
All you can do is try and replace the motor, if that does not work then the door is already apart so just buy a good used one.
www.roverlandparts.com
Either way you need to fix it.
kristofferzen
Sep 10, 2015 02:11 PM
