Door Lock actuators still firing, advise please.
Old Aug 3, 2011 | 05:45 PM
DiscoBenjamin's Avatar
Default Door Lock actuators still firing, advise please.
I can feel the door lock actuators still firing in the doors but what was one lock that was not unlocking when unlocking is now 3. They still lock the doors just don't unlock the doors, any advice as to next steps?
Thank you as always.
Old Aug 3, 2011 | 06:02 PM
renfield's Avatar
I just replaced both front door lock actuators following RAVE; same symptoms. I bought the replacements from Rovers North - they were about $125 bucks each. Take a good look at your window regulators when you do - I had one with two rollers broken, and the other had one broken roller... might as well check and replace them if needed while you have the door open.
The tricky part for me was pulling the rod that connects the actuator out of the connection to the external latch. You do just firmly pull it out and apart. Looks like it's going to break, but mine didn't. You can order replacement clips for a few bucks if they do break.
Plan for 2 hours for the first door, and 1 hour for the second after you see what you are doing (that was my experience).
Good luck.
DaveBFoto
Dec 16, 2010 10:21 AM
rekogniz1
Oct 8, 2009 12:08 PM
shonuff93
Aug 11, 2009 12:39 PM
wesley64
Oct 5, 2008 10:49 PM
