Door Locking Problem
Old Nov 4, 2007 | 07:36 AM
II2Go's Avatar
Default Door Locking Problem
I've been holding my breathe as the door locks on my 1999 Disco II (165K miles) have slowly stopped working. This morning I went out and the rear door is now locked and I cannot open by using key fob or the inside toggle switch. All is dead. I understand there are actuaters that need to be replaced, but is there also on on the rear door? Is there a way to release the door from the inside?
Finally, has anyone offered a step by step process to replace the actuaters? If so, I would really appreciate receiving it. I'm going to attempt to make this a DIY project if I can get comfortable with the process.
Thanks All.
Old Nov 4, 2007 | 10:43 AM
DeepBlueWater's Avatar
Default RE: Door Locking Problem
This may help https://landroverforums.com/m_13854/tm.htm
LR replaced one for me as a warantee item. I believe it would have been over $300.00 (painfull).
I have another that is inoperable - no warantee. I havn't divedinto that project yet but did a bit of research.
MWmG
Old Nov 4, 2007 | 10:53 AM
On the rear cargo door, usually the problem is the linkage getting dirty. Try pulling off the rear Rover emblym and clean and lube the linkage. This usually fixed the problem.
By the way, you can usually buy good guaranteed used actuators from, http://www.roverlandparts.com/index....S&Category=438
for a lot less then going to the dealer.
Old Nov 7, 2007 | 06:44 AM
II2Go's Avatar
Thanks to you both. I appreciate it.
Old Nov 7, 2007 | 09:00 PM
Jst4fun's Avatar
I would recomend NOT trying to rebuild your old actuators, the description is deceiving. To many things to go wrong, can send the pics of mine in many pieces. Mikes suggestion to purchase another one is your best bet.
If you order the actuator and feel unsure of how to do it, send me an email, I can send you my cell number and walk you through it (can do it with my eyes closed).
Good luck!
Regards,
Nick
Old Nov 7, 2007 | 09:01 PM
Jst4fun's Avatar
Oh, here is something fun to read
https://landroverforums.com/m_37497/tm.htm
My wounderful experience!
Old Nov 8, 2007 | 03:35 PM
jigray3's Avatar
I had sticky lube issue on the rear door twice. A good penetrating spray lube under the Rover emblem fixed it.
sc_mark
Aug 8, 2012 01:14 PM
james89
Jan 21, 2010 11:34 AM
johanba
Apr 3, 2007 11:37 AM
william
Sep 25, 2006 05:22 PM
arocena409
Oct 17, 2005 09:41 PM
