Door Locks
Old Jun 28, 2009 | 06:00 PM
kalmdude's Avatar
6th Gear
Default Door Locks
I have a 2001 Disco II with 115K miles - so ite relatively older...
first started with my rear door locks not working - would not open with the remote key opener - now it is the driver side door that cannot be opened with the remote key -
I haev checked the fuse #1 and it looks good -
has anyone come across this problem - and how do you fix it ?
Thanks
Kevin - Dallas, TX
Old Jun 28, 2009 | 06:07 PM
How about when you use the key or dash button. If they still don't work, you will be looking for a couple of door lock actuators, how mechanical are you?
Old Jun 28, 2009 | 06:33 PM
AK Rover's Avatar
If it is isolated to one or two door locks I would think the problem is bad lock actuators. Very easy to replace if you are at all mechanically inclined.
Old Jun 28, 2009 | 10:36 PM
kalmdude's Avatar
6th Gear
Default door locks
Thanks guys -
I am fairly mechanical - where does one buy an actuator ? how much does it cost ? any help on the how to would be most appreciated...
Thanks
Kevin
Old Jun 29, 2009 | 09:08 AM
www.roverlandparts.com used
www.atlanticbritish.com brand new
Old Jun 29, 2009 | 05:41 PM
Rover Chris's Avatar
aftermarket from any mobile electronics shop (best buy mobile department) around $20 each but a little more work to install
Old Jul 2, 2009 | 09:24 PM
skyguy's Avatar
Odd but not long after reading this my drivers door lock stopped working. I can push the lock down and pull it up but it will not work with the remote or switch inside. Did you need special tools to remove the door panel ie: trim puller ?
Old Jul 3, 2009 | 02:53 AM
door panel removal tool is the best to prevent breaking the little plastic retainers but as long as your careful you can usually pry the bottom ones loose and then give the panel a quick jerk without breaking to many if any at all (its ok to break a couple as there are usually about 2 or 3 times more than are truly needed) just be sure all screws are removed first!!!
Old Jul 3, 2009 | 03:33 AM
Helmuth van Es's Avatar
I had to replace 2 locks in my DII and now the rear and the back door lock need to be replaced. Pain in the .. to do but possible
Old Jul 3, 2009 | 10:13 AM
kalmdude's Avatar
6th Gear
keep at it -
i used my son's wooden ruler to pry open very carefully - it worked !
not hard juts be gentle -
now waitimg for the part to show ... the dealership costs for brand new was $195 - too much - so i am going the used/after market route -
or not fix at all :-)
Lisa
Oct 17, 2005 10:00 PM
Lisa
Aug 20, 2005 11:16 AM
Lisa
Aug 8, 2005 10:31 PM
II2Go
May 30, 2005 08:31 PM
Kennydhl
Apr 18, 2005 10:54 PM
