Door Seals
Old Oct 24, 2008 | 08:26 AM
Goose_Cat's Avatar
Default Door Seals
I recently went on a hunting trip to Missouri. The truck did great however, I noticed that every thing in the cargo area had the same dirt covering that was on the rear door. My problem seems to be coming from the fit of the rear passenger doors, mostly the left side. Has any one else run into what I would call a gaping hole between to door seal and the door. The seal seems to be in good condition. On a side note, the truck was so impressive to all of those who rode in it that one of my uncles has already purchased a D1 and I have another who is looking. They couldn't belive the capabilities of the Disco, so I had to show them.
Old Oct 24, 2008 | 11:05 AM
Default RE: Door Seals
Have you tried adjusting the door latch? Open the door, take a star head, or maybe allenwrench and loosen the door latch thingy that is attached to the body, move it out, retighten and close the door. Do this is small adjustments, there is a fine line between good and not good.
If that doesnt work then you may need to adjust your door hinges.
Old Oct 24, 2008 | 11:08 AM
Darover's Avatar
Actually its the door catch that should be moved inward, since the door part is part of the actuator and not adjustable on a D2
Old Oct 24, 2008 | 06:14 PM
CandiMan's Avatar
From researching, I've been told that DII door seals will fit a DI and they are better thicker seals.
Old Oct 25, 2008 | 01:40 PM
apcollin's Avatar
ORIGINAL: CandiMan
interesting. but aren't the DII rear doors longer? i could be wrong about that.
i am in need of new seals on my 96 and would be very interested in upgrading if they are in fact interchangeable...
Old Oct 25, 2008 | 01:52 PM
CandiMan's Avatar
My mistake, I was refering to the passenger doors.
Old Oct 26, 2008 | 02:37 AM
tacomatech's Avatar
Instead of adjusting the striker, adjust the glass frame as it is the most common problem of air leakage. I believe it to be a torx t-40, loosen the glass frame bolts and pull inward on the frame, then tighten again.
Old Oct 26, 2008 | 07:35 PM
Goose_Cat's Avatar
Thanks for the replies. Upon further investigation it appears that the truck has had extensive repair without report. I found that the entire roof has been replaced as well as both front fenders and bonnet. It appears as if I have more work ahead.
Old Oct 26, 2008 | 08:13 PM
So it was in a roll over accident then? That sucks.
Old Oct 27, 2008 | 12:52 AM
tacomatech's Avatar
It sounds like it is time to cut your losses and search for another Disco II with a clean bill of health. Sorry to hear the news.
ngarover
May 12, 2021 09:00 AM
Scott R
Nov 15, 2009 03:29 PM
ryant06
Dec 27, 2007 03:29 PM
FranzUgan
Defender
May 25, 2007 03:20 PM
russwess
Apr 23, 2006 11:15 PM
