door sensor?
Old Jan 18, 2007 | 11:28 PM
crash26's Avatar
Default door sensor?
I have a '98 discovery and when I open the door my dome light blinks on & off. There is also a constant beep as soon as I take the truck out of park that stays on until I put it back in park. The dealer said it was because of a door latch sensor. Is there any way I can bypass the sensor w/out spending $300?
Old Jan 19, 2007 | 11:36 AM
Default RE: door sensor?
If the dealer is sure about this and told you what door switch needs to be replace, I would suggest you replace it your self, I can't imagine it is too much of a problem to get to.
Mike
Old Jan 28, 2007 | 03:52 PM
kip's Avatar
kip
3rd Gear
Same problem here minus the flashing dome light. I gotta go with a fault in the diff-lock circuitry. When in park, no noise, when anything else, constant chime. Wish I could identify fuse for chime! Or find and yank chime.
KlamathMatt
Apr 17, 2020 05:27 AM
jfoley1
Mar 18, 2009 06:52 PM
stupid
Nov 23, 2008 01:17 PM
jmccollister
Sep 9, 2008 08:50 PM
Morgan
Aug 14, 2007 08:15 PM
