Door tumbler broken - Locked Out with No Fob
#23
Originally Posted by uhoh_elmo
Well, took apart my tumbler and it looks like the same exact piece is broken on mine. The retaining wafer.
mln01, did you replace the retaining wafer with anything?
Be sure to carefully clean and lube everything while you have apart. I used carb cleaner to clean the parts. I'd recommend either a spray silicone lube or a spray white lithium lube, or that specialized lube mentioned earlier in this thread after you get it cleaned up.
uhoh_elmo (11-24-2021)
#24
Yep. I cleaned and lubed everything and put it back together without the retaining wafer. There are a couple discos I can grab a door handle from not too far from me so I'll do that probably over the weekend. The chamber for the tumbler did seem to hold the wafers in place, and until I can get some fobs programmed, I'll just be extra careful.
My alarm did go off when I initially unlocked and opened the door. I just unhooked the battery, pulled the tumble to fix, installed everything back, and it's working with no problems.
#25
The following 3 users liked this post by mln01:
Ridgeline Adventures
12-23-2021 12:18 PM
