Dorman 620-112 fitment
Old Jul 24, 2021 | 11:47 AM
Best4x4's Avatar
I've never had to modify the Dorman 620-112 with the Duralast 922790 or the Hayden 2991 fan clutch.
Old Jul 24, 2021 | 12:16 PM
Seattled2's Avatar
Default 922786 Difference ?
I found the Duralast 922786 from another thread… will have to look up the 922790 difference. Drilling out the fan kinda sucked.
Old Jul 24, 2021 | 02:10 PM
Best4x4's Avatar
From what I can tell the 922786 has a longer shaft 36MM nut part, and it uses much larger bolts. I've seen one of these before installed onto a D1 and the OEM fan had to be drilled out as well. It was replaced with a new OEM fan blade (D1 is smaller) and the Duralast 922790. If I'm not mistaken that is probably the Chevy Express van fan clutch. I use the Dodge Dakota US MOTOR WORKS 22151, Duralast 922790, or the Hayden 2991 fan clutch and those are 100% exact match parts. Absolutely zero modifications need to made when using the OEM D2 99-02 Fan Blade or the Dorman 620-112 unit.
Old Jul 24, 2021 | 07:44 PM
Seattled2's Avatar
Default Damnit. Get the 922790 next time for sure
Damn. Wish I got the Duralast 922790. And save myself the drama.
I might just swap it later. It’s on there and spins.. looks balanced. But paranoid any oscillation might cause the water pump to fail prematurely ? I don’t know if 2-3k rpm can be a problem. Either way
getting The 922790 next time. Wish I found out sooner.
Old Jul 26, 2021 | 03:32 PM
NVDiscovery's Avatar
The Dorman 620-112 and the Hayden 2991 worked as advertised for me. I didn't need to use the spacer that was included with the fan. It was so easy, even I could install them!
austinlandroverbill
May 27, 2018 11:14 AM
CollieRover
Jul 16, 2016 01:51 PM
russburcham
Jul 2, 2013 01:55 PM
ebg18t
Sep 9, 2012 07:32 AM
Scharfire
Aug 30, 2012 06:36 AM
