Downstream O2 Sensor Wiring
Old Jul 16, 2020 | 10:07 AM
whowa004's Avatar
Default Downstream O2 Sensor Wiring
Does anyone know if the 2 white wires in the O2 sensor harness matter how they are connected?
Being the genius I am, I cut the rear O2 harness when I took my Y pipe off bc I was tired and was tired fighting with the clips. Figured no big deal I'll just splice them back once I finish welding the pass downpipe back together....went to do just that and found of the 4 wires in each harness 2 are just plain white. Is anyone familiar with this and does it matter how I connect those two back together?
Thanks!
Old Jul 16, 2020 | 11:17 AM
XRAD's Avatar
white wires for heater which is not polarity dependent AFIK. they can be hooked up either way. ......
Old Jul 16, 2020 | 11:52 AM
whowa004's Avatar
That's what I was hoping to hear. Either it was going to work fine or I'd have to redo it and swap them. Thanks!
Old Jul 16, 2020 | 06:41 PM
mln01's Avatar
I don't know why you're seeing two white wires on each connector. Here's the wiring diagram.
Old Jul 16, 2020 | 07:56 PM
Extinct's Avatar
Does not matter
Old Jul 17, 2020 | 03:09 AM
The Deputy's Avatar
This is probably the color code of wires coming from ECU harness going to 02 sensor plug. The heated 02 sensor itself will have 4 wires, a gray (signal -), black (signal +), white (heater), white (heater).
Old Jul 17, 2020 | 06:25 AM
mln01's Avatar
Ah. Got it. Thanks.
Roflcopter
Jan 27, 2017 11:12 AM
BackInA88
Sep 13, 2015 02:05 PM
emt2976
Mar 16, 2014 04:57 PM
Marcoadieter
Dec 6, 2010 09:24 AM
ttlandroverdisco
Oct 14, 2010 09:44 PM
