Drain coolant from block - plug torque spec and sealant needed?
Old Aug 12, 2023 | 01:18 PM
Best4x4's Avatar
On stuff that has build up of junk I've used CLR to break down the junk and then flush it out.
Old Aug 13, 2023 | 02:18 AM
Discorama's Avatar
I put some teflon tape on the plug threads and turned the plugs in hard enough so they can't fall off. I pressure tested the block with air to make sure there are no leaks. Sprayed soapy water around all ports and mating points to make sure. Found indeed a tiny leak at the temperature sensor on the block.
neuropathy
Aug 17, 2022 11:40 PM
neuropathy
Aug 13, 2022 08:56 PM
za105
Aug 4, 2015 04:19 PM
sloppyjoe
Mar 12, 2010 02:23 PM
RamblingMan
Jan 31, 2009 08:10 AM
