Drain coolant from block - plug torque spec and sealant needed?
I put some teflon tape on the plug threads and turned the plugs in hard enough so they can't fall off. I pressure tested the block with air to make sure there are no leaks. Sprayed soapy water around all ports and mating points to make sure. Found indeed a tiny leak at the temperature sensor on the block.
