Drain Coolant from Water Pump Bolt?
Old Aug 16, 2018 | 12:53 PM
CollieRover's Avatar
Default Drain Coolant from Water Pump Bolt?
In he AB head gasket video, he drains the coolant from a bolt in the water pump.
Anyone try this method? Would it affect the seal of the water pump? Sealant on reinstall? Should I stick to the lower hose?
Old Aug 16, 2018 | 12:56 PM
Best4x4's Avatar
It’ll drain the intake manifold of coolant, but the lower radiator hose will allow more to drain out as it’s lower than the water pump.
Old Aug 16, 2018 | 01:01 PM
What is the wisdom of pulling the bolt, and sticking the old wet dry vac on the coolant bottle and blowing it all out? Do you think there could be any detrimental affect to the pump from pulling that bolt?
Old Aug 16, 2018 | 02:20 PM
Best4x4's Avatar
It might seep afterwards as that bolt goes all the way into the water jacket.
Old Aug 16, 2018 | 02:48 PM
I took the leap, so we'll see. I'll put some high temp thread sealant on when it goes back in.
Old Aug 16, 2018 | 02:50 PM
Sixpack577's Avatar
There's a threaded plug on each side of the block for draining coolant too.
Square head, next to knock sensors.
Old Aug 16, 2018 | 03:01 PM
Best4x4's Avatar
Shop vac always does the trick for me. Suck it out or do like Spaceballs & go from suck to blow lol.
Old Aug 16, 2018 | 05:50 PM
haha! Love that movie.
Old Aug 16, 2018 | 06:00 PM
I’ve avoided taking those out. Maybe when I have a garage and am not rolling around my parking lot.
Old Aug 16, 2018 | 08:48 PM
Best4x4's Avatar
That movie rocks!
