Drain Coolant from Water Pump Bolt?
Old Aug 17, 2018 | 02:05 AM
The Deputy's Avatar
That's ludicrous...
Old Aug 17, 2018 | 07:16 AM
mln01's Avatar
Collie, can you please explain the appeal to you of draining the cooling system via the water pump bolt. As Best pointed out, the lower radiator hose is at a lower point in the system. Thanks.
Old Aug 17, 2018 | 07:33 AM
CollieRover's Avatar
Easier to get to, and easier to control the coolant flow. If you keep the coolant bottle cap on it comes out a bit, then not at all, then you unscrew, and bob's your uncle, here comes the coolant.
This is my first time with it, going to pick up a new bolt, the old is a bit haggard, and will report if it leaks at all.
99DiscoFlyer
Jun 2, 2019 02:57 PM
MrWilson
Dec 19, 2018 01:05 PM
duscarter
Sep 26, 2018 09:58 PM
bearskinrug
Nov 15, 2013 08:15 AM
RamblingMan
Jan 31, 2009 08:10 AM
