Drain and Flush
Old May 13, 2013 | 10:55 AM
slabrat's Avatar
Default Drain and Flush
Is there a way to "gracefully " drain and flush the coolant system. I'm getting rid of Dex in the next week or so but I hate to dump coolant all over the the floor and in buckets.
I have seen a flush kit at the parts store not sure what that does. I just am anxious to get rid of dexcool in the 04 and flush the system.
Help is appreciated very good info here
Old May 13, 2013 | 10:57 AM
Big pan. Like from construction aisle. Be sure to reverse flush the heater core as well.
Old May 13, 2013 | 11:10 AM
slabrat's Avatar
Buzz
You mean take off the heater hoses and backflush?
If I dump a bunch in the driveway isn't that toxic to animals and stains pavement? Should I use a hose to flush the radiator and the block ? I have looked on forums and you tube and saw many ways to do it. If i just drain it it makes a mess but if I flush a bunch of gallons it will really make a mess. Should I dispose at parts store?
Confused
Old May 13, 2013 | 11:36 AM
drowssap's Avatar
you have a Land rover and your worried about stains in your driveway? That's the best one I've heard all day
Old May 13, 2013 | 12:13 PM
slabrat's Avatar
Your Land Rover Leaks ?
I try to contain them in the garage. I have 2 Now, one or the other gets to leak on the driveway at all times. Good point.
Old May 13, 2013 | 12:34 PM
drowssap's Avatar
the best thing I have found to use it one of those plastic mason tubs for mixing mortar they are about 24 x 36 x 8"
Old May 13, 2013 | 01:52 PM
Dan7's Avatar
Why...then what's going to get rid of the stray cats?
Old May 13, 2013 | 02:17 PM
slabrat's Avatar
They must have been around for the 99 Disco coolant dump when I did Head gaskets. Haven't seen any around lately.
Old May 13, 2013 | 03:24 PM
Don't buy any of the flushes if you are thinking about cleaning out your radiator cause after 100,000 miles D2 radiators are partially plugged and won't clean out.
Go buy about 5 gallons of distilled water, no tap water flush it thru 2 times, install a new coolant pressure cap and a 180 degree soft spring t/stat and your new coolant and you will be set.
Old May 13, 2013 | 06:39 PM
04duxlr's Avatar
The mason tub is the way to go. I pulled the hoses and dumped the coolant into the tub. I also pulled the heater hoses at the metal pipes over the valve cover and back-flushed it with a garden hose. I used a length of heater hose to lead the inlet to a bucket to catch the discharge. The inlet hose is the one off the intake manifold. I was amazed at what came out of that thing. It made my heat actually work! I used the distilled water flush approach and caught everything I could in the tub, then used a shop vac to clean up everything else. Make sure you get a bunch in your hair and have some run down your arm on the inside of your shirt sleeve. If you're really good, you'll be able to get a couple of good splashes in your mouth also.
