Drain the Radiator?
Old Jul 14, 2012 | 10:33 AM
casejeep's Avatar
4th Gear
Default Drain the Radiator?
Some how i cant find the drain the plug for the radiator... Im planning on flushing the whole system, thus the need for the drain plug location. do i have to remove all of the plastic covers underneath?
Old Jul 14, 2012 | 10:44 AM
There is no drain plug, you'l have to loosen a hose clamp. Once flushed and re-filled with 50:50 premix, you'll have to be sure to purge all air from the system, this is done when cold, usually involves lifting the coolant reserve jug higher. Bleeder valve in T (#11 in drawing) is usually fragile, many have replaced with a brass one, and replacements are like $7 at BMW dealers. You'l want to flush the heater core as well. Flow plan attached.
File Type: pdf
Sackou
Apr 15, 2010 06:23 PM
gtagg
Apr 6, 2007 09:25 PM
werldcup
Mar 23, 2007 11:13 PM
biz1285
Feb 7, 2006 11:17 PM
anonimaus
May 1, 2005 05:01 AM
