Drains
Old Aug 13, 2008 | 06:22 PM
mwvannote's Avatar
Default Drains
Sorry if this has come up before. I did a search and came up with nothing.
The floor of my 2002 Disco II has been soaked for a while now. I think I remember reading about floor drains which become clogged. I also read about sunroof drains but do not see any sign of water ingress besides the floor. Anyone have a quick solution for me?
Thank you.
Mar
Old Aug 13, 2008 | 07:20 PM
Default RE: Drains
Your A/C drain tubes are clogged. It has been covered before but no big deal.
Crawl under the truck and right behind the engine next to the transmission bell housing will be two tubes, squeeze the nipple's and they will drain. You may need to take a pipe cleaner and "ream" out the tubes.
Next take a shop vac to your carpet before you get mold.
Disco2Guy's Avatar
Default RE: Drains
For the a/c drains, crawl under the truck and look up to either side of the tranny tunnel around the middle of the front drive shaft. There are 2 black "cones", these are the drain plugs that get clogged with dirt and mud. It's easier (and safer) if the truck is cold to reach up there and just rub/pinch them. Be prepared to get wet and move out of the way of the falling water. You should check them every couple of months or more often if you wheel in the mud. Welcome!!
Old Aug 14, 2008 | 06:44 AM
mwvannote's Avatar
Default RE: Drains
Perfect. Thanks guys.
frankie_fl
Sep 2, 2008 07:59 AM
nynole
Feb 26, 2008 06:04 AM
joverrover
Sep 8, 2007 09:13 AM
theRange
Sep 7, 2007 03:55 PM
arrkerr
Dec 14, 2005 10:06 AM
