Drilled Rotors worth it?
Old 12-08-2006, 12:00 AM
Willie 00D2's Avatar
Default Drilled Rotors worth it?
My front brake's are about shot. I am trying to decide what rotors to buy Napa wants $85. for un-drilled stock rotors. Expidition exchange wants $120. for their DBA drilled rotors. Do you think I will notice a difference in stopping power and brake component life? I am also thinking about some 2" longer braided hoses. I bought some Hawk HPS pads. I am not a aggresive braker because of the heavy weight of the vehical. I do plan on doing some offroading with it. A 2" lift and 265/75/16 are on the list of mods.
Thank you,
Willie
Old 12-08-2006, 02:04 PM
Default RE: Drilled Rotors worth it?
DBA rotors and Kevlar pads are the greatest stopping power you can have on a Disco, they will out last convential rotor/pad combinations and are cost effective.
You should plan on changing your rubber brake lines to stainless steel and use synthetic brake fluid to keep a firmer brake pedal.
The one thing you can't do is only use DBA's on one axle, have to use them on all four wheels.
I have a set on my 99 D2 and with nearly 58,000 miles on them, they are only 50% warn.
If you want to stay with convential brakes, check out the sale at Atlantic British.
Mike
Old 12-08-2006, 04:17 PM
geoman's Avatar
from Disco Mike......."If you want to stay with convential brakes, check out the sale at Atlantic British"
might I add.......
also check out my reasonable prices on brake kits at www.eurotekapg.com
regards,
Geoman
eurotek apg
Northern California
Old 12-08-2006, 11:25 PM
Thank you, I will buy 4 DBA rotors and stainless lines. Merry Christmas to me!
Thank you,
Willie
Old 12-09-2006, 11:35 AM
Try, http://www.dap-inc.com/homeframe.htm I think they have about the best price for the DBA's and Kevlar pads.
Don't forget to buy 2 qt.s of Vavolines synthetic brake fluid and some sound deadening sparay to put on the back of the brake pads.
Good luck and have fun.
Mike
pgk
05-25-2012 05:04 PM
drowssap
07-07-2011 09:41 AM
jspbtown
23
03-04-2008 09:46 AM
DeepBlueWater
11-29-2007 09:16 PM
Quick Reply: Drilled Rotors worth it?
