Drive shaft fix
I keep seeing "rebuild your drive shaft" , but i never see fix the main issue that causes the drives shaft to fail.. #1... air conditioning drain draining on drive shaft. When they replaced my engine they re plumed mine so it does not drain on the shaft anymore. I will see if i can get pick or a writeup on how they do it at my rover shop.
Thanks Chris
Thanks Chris
This thread gives me an idea- build a quarter-round shield to cover the t-case end if the front d/s. Protect it from a/c drip and converter heat. But it would leave enough open to be able to grease it.
now get your plumbing rerouted so it does not drain on it...solve part of the problem...
Sure you would still need a new driveshaft, but at considerable less cost than that AND a transmission.
Didn't we already have a recent post from someone who actually builds protection loops? See https://landroverforums.com/forum/mo...riveshaft+loop
