Drive shaft fix
Old Mar 3, 2012 | 08:28 AM
vandev's Avatar
Default Drive shaft fix
I keep seeing "rebuild your drive shaft" , but i never see fix the main issue that causes the drives shaft to fail.. #1... air conditioning drain draining on drive shaft. When they replaced my engine they re plumed mine so it does not drain on the shaft anymore. I will see if i can get pick or a writeup on how they do it at my rover shop.
Thanks Chris
Old Mar 3, 2012 | 08:35 AM
While that is one issue, the lack of ability to grease frequently is also a big player.
Old Mar 3, 2012 | 08:40 AM
antichrist's Avatar
It's the bigger player, not greasing them, that is.
Old Mar 3, 2012 | 09:17 AM
kenk's Avatar
This thread gives me an idea- build a quarter-round shield to cover the t-case end if the front d/s. Protect it from a/c drip and converter heat. But it would leave enough open to be able to grease it.
Old Mar 3, 2012 | 09:21 AM
Won't work, the u-joints will still fail when not being lubricated , just from their own internally generated heat.
Old Mar 3, 2012 | 03:42 PM
Dayton Atworth's Avatar
4wd High
why arent these more talked about? this is what i have after my driveshaft broke.
4wd High
Land Rover Discovery
Old Mar 3, 2012 | 04:25 PM
vandev's Avatar
Default thats a start
now get your plumbing rerouted so it does not drain on it...solve part of the problem...
Old Mar 3, 2012 | 06:37 PM
I think that would make the drive shaft last longer, protecting it from the heat of the cat and the water from the a/c and if it was strong enough if it broke it would prevent the driveshaft from destroying the trans.
Sure you would still need a new driveshaft, but at considerable less cost than that AND a transmission.
Old Mar 3, 2012 | 07:05 PM
Didn't we already have a recent post from someone who actually builds protection loops? See https://landroverforums.com/forum/mo...riveshaft+loop
