Drive shaft problems... Can anyone help?
Old Nov 8, 2013 | 03:13 PM
  #21
Sean Ironstag's Avatar
So... Using a mixture of penetrating oil, a pipe for leverage, and some wrenches, I was able to get 3 of the 4 nuts off, but the last one just won't come off. It's stripped now too, just to add even more complication.
Anyone have any advice how to get this stuck stripped bolt off the drive shaft? I've not a clue what to do now.
Old Nov 8, 2013 | 03:31 PM
  #22
SuperSport's Avatar
Channel Locks. If it's too gone for that, then cut with a wheel or chisel.. Sometimes, a small pipe wrench will get it.
Old Nov 8, 2013 | 04:57 PM
  #23
Have tried channel locks, and vise grips. Pipe wrench won't grip in the direction I need it to, and won't fit the other direction. someone suggested I go get a nut breaker, so I did, and all the nut breaker did was mangle the nut. Didn't break it, but mangled the **** out of it.
I haven't a clue what to do...
Old Nov 8, 2013 | 04:59 PM
  #24
SuperSport's Avatar
Probably time for cutting. Once the shaft is out of the way, you can get at the stud better...
Cut the head off the nut, not the driveshaft.
Old Nov 8, 2013 | 05:10 PM
  #25
I'm afraid to cut it for 2 reasons, one is I'm worried about the sparks from my dremel because i have a really bad oil leak down there, and the second reason is I'm afraid of damaging the bolt, because this is on the back side, where you can't get the bolts off, I haven't a clue how I would replace the bolt if I damaged it.
Old Nov 8, 2013 | 05:23 PM
  #26
SuperSport's Avatar
OH, the bolt is stationary and the nut comes off? In that case, there's a tool called a nut splitter. It compresses the nut using a chisel on one side until it cuts off.
Product: Nut Splitter Tools — 2-Pc. Set
Old Nov 8, 2013 | 07:10 PM
  #27
Tried using a nut splitter and it just tore up the nut instead of splitting it, it's still stuck on there.
Old Nov 8, 2013 | 09:11 PM
  #28
xxdoylexx's Avatar
He needs to play more with those nuts
(damn that was to easy)
Old Nov 8, 2013 | 10:41 PM
  #29
dusty1's Avatar
Take it easy, he already tore one.
Old Nov 8, 2013 | 10:42 PM
  #30
dusty1's Avatar
But, you don't have a cutting wheel of some type?
