Drive shaft problems... Can anyone help?
So... Using a mixture of penetrating oil, a pipe for leverage, and some wrenches, I was able to get 3 of the 4 nuts off, but the last one just won't come off. It's stripped now too, just to add even more complication.
Anyone have any advice how to get this stuck stripped bolt off the drive shaft? I've not a clue what to do now.
Have tried channel locks, and vise grips. Pipe wrench won't grip in the direction I need it to, and won't fit the other direction. someone suggested I go get a nut breaker, so I did, and all the nut breaker did was mangle the nut. Didn't break it, but mangled the **** out of it.
I haven't a clue what to do...
Cut the head off the nut, not the driveshaft.
I'm afraid to cut it for 2 reasons, one is I'm worried about the sparks from my dremel because i have a really bad oil leak down there, and the second reason is I'm afraid of damaging the bolt, because this is on the back side, where you can't get the bolts off, I haven't a clue how I would replace the bolt if I damaged it.
Product: Nut Splitter Tools 2-Pc. Set
