Drive Shaft U-joint Question
Old Aug 29, 2010 | 01:39 PM
Rearden Steel's Avatar
Default Drive Shaft U-joint Question
I was just under the Disco getting ready to change the oil and consider pulling the drive shaft out and have the u-joints replaces. I have an 2004 with 45K miles. Much to my surprise the front u-joint does has a grease fitting. The rear double u-joints do not have the grease fittings.
Is the front u-joint the one that blows up?
Thanks,
RS
Old Aug 29, 2010 | 01:43 PM
vandev's Avatar
Default yes
yes, the front shaft fails. with 45k i wouldn't be to worried but i would get it done soon..
chris
Old Aug 29, 2010 | 02:28 PM
Mine failed at 37K, I WOULDE BE CONCERNED AND HAVE IT REBUILT OR REPLACED NEXT WEEK CAUSE A REPLACEMENT TRANNY IS VERY EXPENSIVE.
Old Aug 29, 2010 | 04:11 PM
'BamaBoy's Avatar
Does anyone know a good place in Michigan to get a U-Joint replaced/rebuilt?
Old Aug 29, 2010 | 04:28 PM
Depends on where you are in MI.
I know a place a mile from my house.
Old Aug 29, 2010 | 05:00 PM
bikingteacher's Avatar
Any driveline shop can do this. It is such a simple thing. I brought them the parts and let them do the work, cost me $50 in labor.
Old Aug 29, 2010 | 05:35 PM
antichrist's Avatar
The front u-joint had a fitting from the factory, the two u-joints that are together (the double cardan CV joint at the gearbox) did not. It's the double cardan joint that grenades.
Read the thread linked to in the write-ups section "Rebuilding a propshaft".
If you do have your propshaft rebuilt (u-joints aren't rebuilt) make sure they do the centering ball also.
Make sure you lube it properly, also described in the thread referred to above.
Old Aug 29, 2010 | 08:04 PM
sloan74's Avatar
Man nice score on a 04 with 45k miles. wow.
________
No2 vaporizer
jamieb
May 3, 2012 08:56 AM
pearlorient769
Aug 6, 2010 05:51 PM
ALEXAN
Oct 20, 2009 03:02 PM
AZDISCO
Jun 15, 2008 08:11 PM
disco2adam
Nov 10, 2007 11:02 AM
