Drive Shaft/U Joints -- help & recommendations
Old Mar 12, 2008 | 01:08 PM
Luv2Disco's Avatar
Default RE: Drive Shaft/U Joints -- help & recommendations
Andrew, You need to tell the driveline shop what you need done. Order the parts at Auto-Zone ora similar place. The precision u-joints (3) and centering kit (1) will work just fine. It may take a day for them to get them for you. Then take the parts to the shop and tell them what you want them to do. Alternatively, you can tell them the part numbers that fit and they will either get them or cross reference it to something else they can get. If you have read the threads here in the forum you know what you want done and why. You need to understand that driveline shops work on drive shafts from a variety of equipment, not just cars and trucks. They also work on big rigs, agricultural and oilfield equipment. At least they do here. You shouldn't be surprised if they're not familiar with your Discovery, that doesn't mean they won't do an excellent job.
Old Mar 12, 2008 | 01:44 PM
andrewmcoffin's Avatar
Tom Wood's...just looked up their website...is this a good option? Have others put on this drive shaft?
JEFIII, how did you order? Did you have to provide specs, or do they keep info on file for building a replacement Disco II drive shaft?
Old Mar 12, 2008 | 04:51 PM
If you have to buy a new shaft, Tom Woods is one of the best for around $350, you'll need to give him specific measurements when ordering.
Old Mar 12, 2008 | 05:28 PM
What can you tell me about the rubber coupling on the rear drive shaft? British Pacific mentioned this in an email to me:
"I would first inspect the rubber coupling on the rear driveshaft. That's far more likely to be in need of replacement at 60k miles. Look for cracks in the rubber or any distortion from circular"
Old Mar 13, 2008 | 04:28 AM
antichrist's Avatar
ORIGINAL: andrewmcoffin
That's called a Rotoflex, not unique to Land Rovers. With 60k you're probably going to need to replace it before long, if not now. The more lift you have the sooner you'll need to replace it. It's designed to absorb driveline vibrations and shock loads to some extent.
Tom Woods are good drive shafts, but also heavy duty. If you don't have a lift and do hard core off-roading you're fine with the stock front. It's fine for 99% of rovers.
There is nothing oddball about a DII front propshaft. In fact the u-joints are the same as a volvo, the shop probably has them in stock. Just tell them the PN's mentioned previously. I do really suggest the Neapco though, as you must grease them and the zerk in the end cap makes it a lot easier on the DC.
Since yours isn't currently failed, you have time to shop around. You should be able to get it done for $150-$200 max. $300 is WAY too much.
Old Mar 13, 2008 | 08:29 AM
JEFIII's Avatar
If you decide on the Tom Wood's option, all you have to do is call them and tell them you need the front drive shaft for your appropriate Disco and they want the measurement from the surface of flange on the transfer case to the surface of the flange on the differential. It should be around 24-25". Very simple to measure with a tape or yard stick. That's it. You'll receive it in a few days. Two 9/16" wrenches are all that's needed to remove the nuts on your old shaft and install the new one. Hope this helps. JF
Old Mar 13, 2008 | 10:33 PM
So, what's the consensus? I'm willing to spend $350 on the Tom Wood's drive shaft if it's money well spent. It sounds like it would cost that much to have a driveline shop rebuild my current shaft for me anyway. Am I getting a superior, more reliable, longer lasting shaft by replacing the whole thing with a Tom Wood's?
If I were more confident with this stuff, I'd try to do the rebuild myself--but I'm not, and so I'm tempted to just buy the Tom Wood's shaft and be done with it. But I also don't want to throw money at something that I don't need to, or that's not really going to put me in a better position...
Also, what grease/tools to I need to do the regular maintanence on the Tom Wood's shaft?
At this point, I just need to be pushed in one direction or another by those with more knowledge and experience...I'm actually enjoying learning about all of this, and really appreciate the advice on this board.
Old Mar 14, 2008 | 05:32 AM
goldfishy's Avatar
I thought the Neapco brand was not a recommended manufacturer, meaning you get what you pay for? Don't mean to step on toes here. There was a couple of better made products.
Old Mar 14, 2008 | 09:25 AM
okdiscoguy's Avatar
Call a driveline shop and have your shaft re-built with Spicer U-joints. That should be all you need. I didn't read back through the whole post, but unless you are doing some serious off roading, this will be more than good enough. The main thing is getting the grease fittings in there. The shaft is plenty strong. If you are looking to replace your rear shaft with a Tom Woods, you may have to change the adapter at the rear diff. Right now you have a rotoflex, and it will need to be switched to an open yoke to accept another U-joint on the rear.
Just replace the joints you have with one's you can grease and throw a new rotoflex on it.
Old Mar 14, 2008 | 09:35 AM
Philhowe's Avatar
I went with a Tom Woods Shaft and am VERY happy with it!!!!!! Plus no shipping charges is great as well. (Yes I know it is built into the charge but it still sounds good!)
