Drive Shaft/U Joints -- help & recommendations
Old Mar 14, 2008 | 10:41 PM
  #31
Luv2Disco's Avatar
Default RE: Drive Shaft/U Joints -- help & recommendations
ORIGINAL: antichrist
ORIGINAL: Luv2Disco
Oneother thing, theywill not install any"cheaper" parts such as Neapco or Precision so you should probablyjust take them the numbers for your joints and centeringkit and let them source and supplythem. They'll use Spicer parts if available for your application.
LOL Too funny. I bet you dollars to doughnuts they don't even know that Spicer doesn't make the 5-4x u-joints. In fact, I think Neapco has done some 5-4x production runs for Spicer because some had the zerk fitting in the end cap, which only Neapco has. But people will believe what they want.
I hear you. I started to get "spun-up" when he spouting that but I figured, "what the hey" at least they're gonna use the best parts they can find so let him think what he wants. I myself bought Precision joints for my shop to install in my truck. I asked my tech if they were O.K. and he said they were just fine, that theyused them all the time with no problems. I figured he knew what he was talking about since it's a very busy shop. Anyway, my shaft looked like new when they re-installed it. I'm sure theWoods shaft is great but probably overkill for me. With the money I save I'm throwing an Optima battery in it. By the way, I was pricing them at Sam's club and they told me they do a 100% free exchange if the Optima fails in the first two years. After that it's pro-rated. free install also.
Old Mar 15, 2008 | 08:53 AM
  #32
antichrist's Avatar
ORIGINAL: andrewmcoffin
Luv2Disco: Thank you for making that call. It clearly helped for them to be speaking with someone who knew what they were talking about. At least I know this may be an option still.
D2000: How did the Tom Wood's install go? Did you have to replace the adapter at the rear differential?
Personally I wouldn't use a Spicer 5-4x u-joint since I have no way to know who made it. But it's your choice of course.
Ok, I'm confused now. I thought it was your front propshaft you want to rebuild. you don't need to do anything to the rear shaft when you do the front.
If your rotoflex coupling is cracked, then yes, you should replace it. If you don't have like a 2" or 3" lift the rotoflex is fine and you can get them for $30-$40. A BMW one fits, can't remember which model BMW.
If you do decide to go with a rear Tom Woods (or GBR, which is what I have in the rear) then yes, you need to swap out the pinio flange on the diff. My GBR shaft came with a replacement 4 bolt flange, so I expect the Tom Woods does as well.
Old Mar 15, 2008 | 11:35 AM
  #33
OJs DNA's Avatar
Okay here goes the first post, the only thing that is confusing reading this thread is that half of you speak to replacing the u-joints with greasable u-joints - I got that. But the other discussions are centered around getting a new or repairing the driveshaft, so which is it? To fix the common probelm problem here are we replacing u-joints or driveshafts, or both?
Old Mar 15, 2008 | 12:24 PM
  #34
Luv2Disco's Avatar
ORIGINAL: OJs DNA
You have two choices.Cheapest choice is to simply haveyour driveshaft rebuilt BEFORE it breaks and needs to be repaired or replaced, this is simply a matter of replacingthree (greaseable) U-joints and the centering kit. Any shop you use should clean up the shaft, possibly paint it, and also balance it too. The second choice is to go with a new replacement driveshaft from an aftermarket supplier. This will cost more but may be worth it depending on how you use your truck.My shop suggested I spend $400+ for an aftermarket driveshaft but I decided to have it rebuilt at a driveline shop for about $175.
Old Mar 15, 2008 | 01:04 PM
  #35
andrewmcoffin's Avatar
Thanks for helping to clarify...I thought that this might be the source of confusion. It is the FRONT shaft that is likely to fail, needs, the greased fittings, and could be replaced with the Tom Wood's option, right? The REAR shaft is not as likely to fail, aside from the rotoflex cracking?
Or do I have that wrong?
By the way, what is the GBR option?
Old Mar 15, 2008 | 04:33 PM
  #36
antichrist's Avatar
Correct. Though eventually the u-joint near the gearbox will need to be replaced. I put on a GBR propshaft years ago so can't remember if the OEM shaft had a zerk in the u-joint or not.
Great Basin Rovers
Old Mar 15, 2008 | 04:39 PM
  #37
antichrist's Avatar
Hopefully for some clarification. See image below.
3 -- Single cardan u-joint (OEM is greasable)
1 -- Double cardan u-joint (OEM is not greasable) -- Also contains the centering kit
4 -- Single cardan u-joint (I can't remember if OEM is greasable)
6 -- Rotoflex
[IMG]local://upfiles/7701/B3695F63BE804AFC8DF58626C73628C8.jpg[/IMG]
Old Mar 17, 2008 | 12:43 PM
  #38
Thanks. That drawing is very helpful.
So most of you have modified or replaced the front shaft, but done nothing to the rear shaft (aside from replacing the rotoflex when necessary)...is that right?
And if I order from Tom Wood's, they'll know I'm talking about the front shaft?
Old Mar 17, 2008 | 01:32 PM
  #39
JEFIII's Avatar
Talk to Josh at Tom Wood's. He just sent me mine last week. VERY easy. Just have the flange to flange measurement handy. Great place. great service, great product. You will,not be disapointed. Call me if you have any questions. 912-663-0909. JF
Old Mar 17, 2008 | 11:16 PM
  #40
ChiefII's Avatar
I just wanted to put in a plug for www.driveshaftsuperstore.com Their heavy duty front driveshaft has worked out great for me. The shaft comes with a greasable center bearing as well. I actually had a non-cardon (Disco I) front driveshaft installed on my Disco II. Due to this unusual configuration I had to also purchase a front flange kit in order to mount the new shaft. Also went with the roto-flex kit and a new Neapco 1-0005 u-joint in the rear. I had to enlist the help of a local driveshaft/performance shop to pull out and press in the roto-flex pilot bushing. I don't foresee the need to do anyhing else to the driveshafts except for reqular lubrication with synthetic grease. During the install we also drained and refilled the differentials. Now all that is left to do for the drivetrain is drain and refill the transfer case. Be Safe, Mark V.
ask for Oscar
Maksymyk's Performance-Drvshft [/align] 701 Denton Blvd NW, Fort Walton Beach, FL
(850) 862-0821
ask for Steve - he will probably be the one answering the phone
[/align] [/align]
