Drive Shaft/U Joints -- help & recommendations
Old Mar 19, 2008 | 10:55 AM
  #51
andrewmcoffin's Avatar
Default RE: Drive Shaft/U Joints -- help & recommendations
So, ChiefII, you replaced both your front and rear shafts? Why did you replace the rear shaft?
Old Mar 19, 2008 | 12:00 PM
  #52
Shouldn't have replaced the rear, they don't need to be changed, just greased and once every 80K or more, replace the roto flex.
Old Mar 19, 2008 | 12:08 PM
  #53
IanHand's Avatar
Looking into the entire front Driveshaft replacement for my 2004 SEwith 80k. Having a hard time finding someone to do the rebuild in my neck of the woods (Alton Bay, NH). It appears no one wants to mess with my Rover? Have an e-mail into the Driveshaft Superstore, hopefully they can help me out. In the meantime, if anyone does know of anyplace in my vicinity willing to do the rebuild work, please feel free to let me know. Much appreciated!
Old Mar 19, 2008 | 08:52 PM
  #54
ChiefII's Avatar
ORIGINAL: andrewmcoffin
__________________________________________________ ______
Andrew, check out my original post from March 17 - "Also went with the roto-flex kit and a new Neapco 1-0005 u-joint in the rear. I had to enlist the help of a local driveshaft/performance shop to pull out and press in the roto-flex pilot bushing."
Sorry for the confusion. I was refering to a (like)new driveshaft in the rear. Full roto-flex kit and ujoint. Be Safe, Mark V.
Old Mar 20, 2008 | 11:22 AM
  #55
ORIGINAL: Luv2Disco
Andrew, I called coast driveline and asked them to estimate the labor on what you need done. After some discussion they told me labor shouldn't cost more that $100 bucks. The reason they want you to bring in the shaft and are hesitant to quote a price is because they want to make sure they have the equipment (flange attachments) to do the job right. After looking at coast driveline's website and talking to them I can't imagine them not being able todo it. Seems tobe an awesome shop. Oneother thing, theywill not install any"cheaper" parts such as Neapco or Precision so you should probablyjust take them the numbers for your joints and centeringkit and let them source and supplythem. They'll use Spicer parts if available for your application.On the other hand, for another $100-150 bucks you can get the Tom Woods shaft. These are your choices, just depends on how much money you want to spend.
Luv2Disco, thanks again for calling the shop. Who did you talk to at Coast Driveline--do you recall? I'm still trying to decide whether to buy the Tom Wood's or try to get Coast to rebuild my shaft.
Old Mar 20, 2008 | 06:27 PM
  #56
egreenbuilt's Avatar
6th Gear
I am looking at replacing the u-joints in the front-drive shaft of my 03 disco.I have a drive line shop that will do the work. The shop needs the shaft for three days to rebuild it. Can i drive the vehicle without a front drive-shaft?
Thanks
Egreen
Old Mar 20, 2008 | 06:38 PM
  #57
jkid's Avatar
ORIGINAL: egreenbuilt
Thanks
Egreen
No, not if you have the original transfer case in it. You can't lock the TC on that year.
Old Mar 20, 2008 | 10:27 PM
  #58
Luv2Disco's Avatar
ORIGINAL: Luv2Disco
Andrew, I don't remember his name but he remembered someone had called about a Land Rover so it was probably the same guy you had talked to earlier.
Old Mar 21, 2008 | 03:45 AM
  #59
antichrist's Avatar
ORIGINAL: IanHand
You have a PM.
Old Mar 24, 2008 | 09:01 AM
  #60
raid13's Avatar
doppped my spair front drive shaft off at coase driveline and gear sat 3.22.08
will update all of you when it's done and the final cost.
