Sponsored by: CARiD
Need Help 97' Disco.---Clinging Noise in Driveline
Old Jun 26, 2007 | 02:42 AM
Disco_Drew's Avatar
6th Gear
Default Need Help 97' Disco.---Clinging Noise in Driveline
Thanks in advance to anyone that can help, My 1997 disco seems to be having a problem with the driveline. when the vehicle is shifted from park to either reverse or drive there is a clinging noise. and then when it is traveling down the road it is also sometimes prevalent. the noise to the closest of my ability to describe sounds like a wrench clinging against a aluminum pipe. Is this a U-Joint that needs replacing I am hoping that it is not the transfer case due to the lack of money for buying a new one.
Drew
Old Jun 26, 2007 | 07:11 AM
Default RE: Need Help 97' Disco.---Clinging Noise in Driveline
You better check, lube or replace any or all u-joints, sounds like one or more may be failing, how often do you grease them?
Mike
Old Jun 26, 2007 | 07:22 PM
Disco_Drew's Avatar
6th Gear
I usually use a spray on synthetic grease every time after i go on the trails. I havent rebuild them yet but i think that i might. I got under the truck this morning and turned over the transfer case by hand with the truck on a lift. i noticed that there is about about 3-5 degrees of rotation before the rear diferential engages the shaft to the tires. any thoughts thanks mike
Old Jun 26, 2007 | 07:36 PM
The rotation is normal. The spray won't help much. If you are using a synthetic grease once or twice every 12,000 is usually pretty good, just don't over grease and blow the seals out.
Mike
Old Jun 26, 2007 | 08:24 PM
Disco_Drew's Avatar
6th Gear
I'll try taking the U-joints apart and servicing them then I'll get back to you.
Old Jul 27, 2007 | 05:20 AM
Pierre's Avatar
Surelynew UJs can't be that costly. I think they are a common size (Hardy Spicer?). Do they have grease nipples? If not, and you do a fair bit offroad, replace them with greasable type.
HTH
Pete
Dane!
Mar 11, 2014 05:11 PM
Dane!
Feb 24, 2014 08:32 PM
b18cx
Sep 24, 2008 09:51 PM
SICSOLX
Nov 12, 2007 12:21 PM
