brakes drag/squeal around corners at highway speed
Old May 5, 2015 | 09:40 AM
WaltNYC's Avatar
Default brakes drag/squeal around corners at highway speed
New brakes...pads rotors in front and pads in the rear. Travelling down a winding 60 mph highway last weekend the brakes (mostly front) began to squeal/squeak around curves. When I lightly step on brakes the squeal stops.
I'll admit to not doing the job myself (no time). The fact that brake pressure clamps the pads and stops the squeal rules out other driveline/axle possibilities such as CV joints.
What should I be looking into? Hub nut not sufficiently torqued?
Old May 5, 2015 | 09:51 AM
drowssap's Avatar
More than likely some did not install any type of antisqeal device. And the pads are rattling, have them take the calipers off and apply a coat to the back of the pads, i like permatex brand
Old May 5, 2015 | 11:28 AM
Racer X's Avatar
Hub articulation. Bearings are adjustable on the DI, right? Might want to check the adjustment and correct as necessary.
If they're unit bearings like on the DII, then it's hub/ bearing replacement time.
Old May 5, 2015 | 11:57 AM
WaltNYC's Avatar
Racer...what do you mean by 'adjustable' versus 'unit' bearings. Either way, wouldn't they squeal all time?
They are about three years old and never seen mud or wading of any kind. Hard rain is about as wet as they get.
They are SKF BR37 bearings....
Amazon.com: SKF BR37 Tapered Roller Bearings: Automotive Amazon.com: SKF BR37 Tapered Roller Bearings: Automotive
Old May 5, 2015 | 12:06 PM
Racer X's Avatar
Part 1 (the general idea):
Part 2 (how to use a dial guage):
Old May 5, 2015 | 12:22 PM
WaltNYC's Avatar
OK, that is what I figured and meant by "hub nut not sufficiently torqued" aka: end float adjustment.
Thanks
Old May 6, 2015 | 09:15 AM
MM3846's Avatar
Do you have the anti-rattle springs?
[IMG][/IMG]
Mine did that, all I needed was new springs.
CaptainCulp
Aug 24, 2013 03:17 PM
bonstarweims
Jun 21, 2010 08:44 AM
open range
May 16, 2008 06:09 PM
SICSOLX
Nov 12, 2007 12:21 PM
soupdogg
Sep 25, 2007 12:49 PM
