Driver’s seat lumbar pump?
Old Mar 2, 2025 | 12:39 PM
longtallsally's Avatar
Default Driver’s seat lumbar pump?
Since picking my Disco up from storage for a good while and going through things, I noticed the lumbar pump on only the driver’s side isn’t working.
The passenger side works perfectly. All other functions work on the driver’s side (forward and back, tilt, and recline).
I took the switch apart just to play and cleaned it up and reinstalled and it still doesn’t work. I checked the fuses under the passenger seat and all fuses are good. I also verified I can hear the relay or click or whatever for the deflate function.
Where else should I be looking? Do I need to remove the seat?
Old Mar 2, 2025 | 12:52 PM
Boy am I dumb and/or lazy sometimes. So I started looking around and realized there are separate fuse “blocks” for driver and passenger side. Duh.
Anyway, sure enough I check the fuse for the driver’s seat and it is blown. Replace it and it popped immediately. I’ve personally never believed you just replace fuses- they ALWAYS blow for a reason.
That said, since I obviously have a short somewhere, where do I start? I think I’ll have to pull the seat, but wondered if there was any other experience out there on this one.
Old Mar 2, 2025 | 01:08 PM
As I always seem to do, I just keep researching. I found this picture in the RAVE, and now am sure I’ll have to remove the seat. Bummer. The motor is component 11.
Old Mar 2, 2025 | 04:35 PM
Harvlr's Avatar
On 20 year old cars, fuses do sometimes just blow. But obviously if the replacement fuse also blows you have an issue to fix.
jastutte
Apr 6, 2023 06:25 PM
Andy flint
Mar 14, 2023 01:25 PM
WYRover
Jan 31, 2017 10:17 AM
jrk26
Apr 14, 2010 06:46 PM
hammbone930
Dec 24, 2008 07:09 PM
