Driver door strap broken?
Old Oct 23, 2012 | 12:13 PM
countryman's Avatar
Default Driver door strap broken?
Well, not exactly broken but the bit that seems fixed to the door pillar on the passenger side, kinda floats about on the driver side. As you open the door, it goes 'crack' and when you shut the door..again 'crack'. Is something easily fixable ? By me ? Or is it megabucks in the shop?
TIA
Old Oct 23, 2012 | 12:15 PM
bballjames's Avatar
TIA
I have the exact same issue. I can even see someone tried to spot weld it to fix it, but doesn't seem like it lasted long.
I just don't worry about it.
Old Oct 23, 2012 | 01:49 PM
jafir's Avatar
It's all replaceable or repairable. Not sure about how difficult. The design has changed over the years. My 99 looks different than my 2003. I'll have to take some pictures, because I don't remember exactly what was different.
ASR2098 - bracket
BDH700030 - door check
FS106161ML - bolt
BDM100050 - check pin
Old Oct 23, 2012 | 04:07 PM
lr2001silver's Avatar
Banned
Fixable you need to find a decent welder. Spot welding does not hold up and the metal behind is soft so if you cut a small plate to put between the door jamb and the hinge weld plate to door jamb and hinge to plate good weld only have to do it once. Hope that helps! Lots of disco's have this happen to them.
Old Oct 23, 2012 | 09:15 PM
coors's Avatar
Mine goes crack every time I open my driver door. Friggin annoying. I pulled the door panel removed and replaced the hinge w/ one I got from a parts truck. Guess what!? It was worse than before.
Im sure someone sells the hinge. I didnt notice any damage to the mounting plate. Its gotta be the hinge.
Old Oct 23, 2012 | 09:52 PM
Banned
Like i said I bet the majority of us have seen this or have had it ourselves but seriously look into what i am saying and it will make sense to you. Its not the hinge in "most" cases its the factory spot weld where the hinge meets the jamb. Coors i have seen them how your describing it too.
sidescrollin
Dec 16, 2021 05:15 PM
greg409
Feb 24, 2010 12:35 AM
ahayball
Oct 29, 2009 11:26 PM
04BluDisco
Dec 7, 2008 02:05 PM
kcirtap
Sep 26, 2007 09:39 AM
