Driver door stuck shut!
Old Jul 19, 2019 | 10:12 AM
Hewentto's Avatar
Default Driver door stuck shut!
I've got a good one for you guys.
I just got a 2002 Land Rover Discovery 2 about a week ago, and have been using these threads to fix a whole slew of problems. My driver outside latch was not working without a good tug, so I loosened the thread on the inside and it started opening every time. Accidentally locked the door, And now the outside latch and the inside latch won't open the driver's door.
1. Key does not turn in the door, so I have never been able to lock this car
2. I've opened the door panel as much as possible, and pulled the wire that the inside latch activates when pulled.
3. I've taken out the trimming around the window and pushed down on the switch that is activated when you pull the outside latch.
4.Unlocking the doors from the inside does move the rod up but still can't open the door.
Any ideas?
HunterS
Feb 5, 2019 09:05 PM
huggi
Apr 23, 2018 09:45 AM
SuperSport
Jul 23, 2014 01:04 PM
pgk
Mar 26, 2012 08:02 PM
leddifer
Mar 18, 2011 08:56 AM
