Driver / Rear door lock actuator
Old Nov 11, 2015 | 05:51 PM
clint70's Avatar
Default Driver / Rear door lock actuator
So, yesterday... my 2001 D2's driver and rear main door locks stopped working. Don't really know where to start. Hoping it's a fuse or something simple. Using the FOB to lock the doors, all except the two work fine.
Thoughts? Really could use everyone's input. I do have a donor truck with actuators (that work - I hope). But don't want to do the work if not needed. Thanks
Old Nov 12, 2015 | 02:53 AM
batard's Avatar
You're sure they both stopped working at the same time, right? If so, it's highly unlikely to be mechanical failure of both actuators. Probably some sort of electrical issue you'll have to investigate further.
Old Nov 12, 2015 | 09:04 PM
clint70's Avatar
Actually I am not 100% on that, and I am playing around with the locks right now. It seems like the actuator just died on the drivers side. Not sure about the rear door and when it stopped working. For the moment I will focus on the drivers door.
Does anyone have experience with the replacing the actuator? Can I do a quick disconnect of the old one and plug into the replacement to see if it will actuate? Just to confirm that it will work before going through the process of taking apart and putting back together... without knowing.
Thanks for help.
Cheers!!
Old Nov 12, 2015 | 10:13 PM
batard's Avatar
I replaced my driver's door actuator earlier this year. It's a straight-up plug-and-play and you can probably test it, although not fully because you won't have the mechanical bits installed. I'm not aware of any way to do any of this "quickly," though. You'll have to at least remove the door card, pull back the plastic lining and unplug the electrical connector. It may be difficult to get the electrical connector into the new one to test it because the fit is kind of tight. It's not a tough job, but it's a fiddly one that involves removing a lot of parts, including loosening up the window frame at least on the front ones.
FRLNDR
Freelander
Jan 13, 2016 04:25 PM
korperlich
Jan 8, 2011 12:41 PM
