Driver window
on
RE: Driver window
ORIGINAL: ajh
Why would you suggest a water soluable grease for this application vs one that will stay on when it gets wet like Moly?
on
RE: Driver window
ORIGINAL: Blatallic
Okay I installed everything,.....BUT the window only goes up half way...Could have they sent me a rear part instead of a front...this is really frustrating...
on
RE: Driver window
ORIGINAL: Blatallic
They looked the same...actually they sent me the passenger front door....Go-figure lol....
Now im in a delima cause they wont accept the park back since I lubed it all up...lol....
I ordered the front left one so It'll be here saturday...
RE: Driver window
Same thing happened to me after a little research I found the plastic washer at lowes. a package of 4-6 for 99 cents! I don't remember the size of the washer but if you bring the plastic thats broken off to lowes try and match it up. The one i bought was a little smaller so I threw 2 of them on the oven and when they were hot enough to bend, I bent them over the spot where they go. you need to stack 2 together so they keep the thickness and bam! 99 cent fix when land rover wants you to spend over 200.
