Driver's door window does not move
Old Sep 27, 2016 | 03:08 PM
LuisGT3's Avatar
Default Driver's door window does not move
Hi guys,
My driver's side window will not go down or up. Luckily it's stuck in the up position currently but it doesn't work. When I hit the switch I can hear the clicking as if that end of it is working, but the window doesn't work.
Have any of you experienced this? What do I need?
Any help would be greatly appreciated.
Old Sep 28, 2016 | 03:25 AM
batard's Avatar
It's likely a regulator. Google and you'll find lots of info/instructions on how to fix it.
Old Sep 28, 2016 | 09:10 AM
number9's Avatar
Probably hear some noise in door too if reg?
Old Sep 28, 2016 | 09:29 AM
batard's Avatar
I thought he was referring to a sound at the regulator motor (in the door), but I could be mistaken. It's not totally clear.
Old Sep 28, 2016 | 10:12 AM
The Decider's Avatar
I had a similar issue. I took the panel off and I was expecting to replace the regulator so I unplugged the connector and checked for power and looked at the regulator to see what I was in for. Just for kicks I took the end of a hard plastic screwdriver and rapped the regulator a few times pretty hard. I then plugged it back in, boom back on line. Seems it jammed up internally. Worth a try.
Old Sep 28, 2016 | 01:17 PM
LuisGT3's Avatar
It was the switching/clicking noise by the actual switch. No noise by the door, but the other windows make that same noise as if electricity is being activated by the switch.
Old Sep 28, 2016 | 01:30 PM
Same here, no indication the regulator was being energized. Faint noise at the switch.
Good luck
Old Sep 30, 2016 | 12:23 AM
toofaroffroad's Avatar
Same thing happened to me. Bought a D2 last summer with a dead window. When I pressed the button I heard a clicking sound.
Pull all the panel and bits off the door. Atlantic British has a good video for this. Then unplug the regulator. Do an electrical test to see if there is a signal on the plug going to the regulator. If there is then it's your regulator. They are cheap and easily to replace. Just make sure you are patient. My window mount was totally rusted out as well. Depending on the state of your Disco you might want to buy the regulator with the entire window mechanism.
Old Oct 14, 2016 | 10:22 AM
LuisGT3's Avatar
The issue was a bad window regulator and switch. Thanks for your help.
jfall
Dec 2, 2022 02:02 PM
GPSK61
Apr 4, 2016 03:50 PM
tacomatech
Oct 22, 2008 10:08 PM
