Drivers seat issues
Old Apr 12, 2022 | 08:49 AM
ABC's Avatar
ABC
8th Gear
Default Drivers seat issues
I'm having some issues with my disco 2 drivers seat side closer to center console seems to be lower than the other side causing my seat to be crooked I was also chasing a heated seat issue and found this harness munched by the lower side of the seat anyone know what it does and how to relevel the seat
Old Apr 12, 2022 | 07:00 PM
Extinct's Avatar
Looks like the harness for the seat heater for the upper?
Old Apr 12, 2022 | 09:28 PM
redrover75's Avatar
this Is what the underside looks like I don't see I don't see an adjustment that looks like like what you're describing. Unless the left and right screws got out of alignment. In which case maybe you could manipulate the screw rides to adjust it. Hope this helps.
Old Apr 16, 2022 | 05:41 AM
The Deputy's Avatar
My guess would be that the springs are weak or cushion material has deteriorate...causing loopsided height. The two threaded screw mechanisms are for moving the seat forward and back, really shouldn't have much to do with height. Yeah, wiring harness looks like heated seat issue.
Old Apr 16, 2022 | 08:15 PM
ABC's Avatar
ABC
8th Gear
Thanks for confirming my suspicion about that wire going to the heated seats it was the only reasonable answer since the seats still move forward/back up/down and about the lopsided seat here is a picture showing it visiblly crooked so I don't think it's saggy springs. Headliner is down for leaky sunroof
Old Apr 17, 2022 | 03:31 AM
The Deputy's Avatar
Yeah, much more serious than just weak springs...you need to pull seat and inspect frame.
Muppetry
Dec 11, 2021 03:43 PM
DiscoBuckeye
Jun 12, 2016 08:29 AM
erick846
Oct 1, 2015 10:23 AM
Tomzsix
Feb 24, 2014 10:49 PM
rover2003
Nov 7, 2007 09:53 AM
