Drivers Side Draft
Drivers Side Draft
Does anyone else experience a draft inside the vehicle while driving? On my D2 its right about head/neck height and quite frustrating. On some of the colder mornings I've had to wrap a scarf around me or assume a center driving position.
It's not the windows and I have no water leaks. It feels like its something around the A or B pillar higher up.
This may seem like a simple question, but I painted my headliner last year and had to remove trim and pillars to get to it. It's very possible I missed something on re-install.
Ironically I've experienced a similar thing in the D2, I reckon it's often when just starting and the blower pushes warm are around and the cold air drops down at the front as it entrains by the warm air into the cabin. It only happens until the heater warms up but you'll still notice that there is plenty of cold air around the drivers door area.
I have the same issue with my DII. It started this year after I had the headliner reupholstered. I'm hazarding a guess it's the seal on my back passenger window as it sounds a bit windy back there and the draft wafts up into the driver's seat and wraps its way around my head and neck. I've poked around a bit but haven't pinpointed the culprit yet. Coincidental that it started when the headliner was removed and recovered? Probably not.
