Drivers Side Signal Light Problem
Old Jan 8, 2020 | 09:50 AM
Sean Winter's Avatar
Default Drivers Side Signal Light Problem
I'm having a familiar issue like others. My drivers signal works fine, except when my headlights are switched on.
I've change the light insert and bulbs. No effect. Then I saw this burn mark. Do you think I should but the connector and install a new one?
Thanks
Sean
Old Jan 8, 2020 | 10:49 AM
Jason Feuerstein's Avatar
Thanks
Sean
That looks fairly important. I would certainly say it needs fixing.
Old Jan 8, 2020 | 11:06 AM
Whats the best way to connect the new connector. 3 Posi-Locks? or just traditional connectors and taped?
Old Jan 8, 2020 | 11:29 AM
I would try and find a new socket and connector with pigtail if possible, but from experience it can be very difficult, as they tend to be LR-unique. You may have better luck with a new socket with integrated pigtail and a generic 3-pin connector.
Old Jan 8, 2020 | 11:44 AM
I cut a socket off an old LR with wires still attached. I was wondering the best way to connect the 3 wires. Since this area gets water splashed up on it.
Thx
Sean
Old Jan 8, 2020 | 11:49 AM
Thx
Sean
I would use heat shrink butt connectors. No need for tape, although I suppose you could do it anyway.
Old Jan 8, 2020 | 12:31 PM
Sixpack577's Avatar
Thx
Sean
Best way to connect them is to twist the wires together and solder them, and cover with heat shrink.
11chuck
Dec 20, 2019 07:44 PM
scader
Oct 3, 2019 02:26 PM
Rufflyer
May 19, 2019 10:32 AM
archaeology_student
May 25, 2018 04:15 PM
jhaller
Jan 29, 2012 02:38 PM
