Drivers Window stuck?
Had the same thing happen to my 01 Discovery. The plastic wheel in the actuator is more than likely broken, assuming you hear the motor still going. I removed the inside door panel and accessed the motor/acuator assembly and replaced it with a new actuator. The toughest part is dealing with the inner vapor barrier if you ask me. It is a do it yourself if you are just a little patient.
Look for a land rover discovery workshop manual online (CD for the computer). Ebay is a good start. Best 15 bucks I ever spent! good luck.
twoxred
10-04-2021 07:07 AM
